Frida 安卓平台追踪脚本
- var isLite = false;
- var ByPassTracerPid = function () {
- var fgetsPtr = Module.findExportByName("libc.so", "fgets");
- var fgets = new NativeFunction(fgetsPtr, 'pointer', ['pointer', 'int', 'pointer']);
- Interceptor.replace(fgetsPtr, new NativeCallback(function (buffer, size, fp) {
- var retval = fgets(buffer, size, fp);
- var bufstr = Memory.readUtf8String(buffer);
- if (bufstr.indexOf("TracerPid:") > -1) {
- Memory.writeUtf8String(buffer, "TracerPid:\t0");
- console.log("tracerpid replaced: " + Memory.readUtf8String(buffer));
- return retval;
- }, 'pointer', ['pointer', 'int', 'pointer']));
- // setImmediate(ByPassTracerPid);
- (function () {
- let Color = { RESET: "\x1b[39;49;00m", Black: "0;01", Blue: "4;01", Cyan: "6;01", Gray: "7;11", "Green": "2;01", Purple: "5;01", Red: "1;01", Yellow: "3;01" };
- let LightColor = { RESET: "\x1b[39;49;00m", Black: "0;11", Blue: "4;11", Cyan: "6;11", Gray: "7;01", "Green": "2;11", Purple: "5;11", Red: "1;11", Yellow: "3;11" };
- var colorPrefix = '\x1b[3', colorSuffix = 'm'
- for (let c in Color) {
- if (c == "RESET") continue;
- console[c] = function (message) {
- console.log(colorPrefix + Color[c] + colorSuffix + message + Color.RESET);
- console["Light" + c] = function (message) {
- console.log(colorPrefix + LightColor[c] + colorSuffix + message + Color.RESET);
- function uniqBy(array, key) {
- var seen = {};
- return array.filter(function (item) {
- var k = key(item);
- return seen.hasOwnProperty(k) ? false : (seen[k] = true);
- function hasOwnProperty(obj, name) {
- try {
- return obj.hasOwnProperty(name) || name in obj;
- } catch (e) {
- return obj.hasOwnProperty(name);
- function getHandle(object) {
- if (hasOwnProperty(object, '$handle')) {
- if (object.$handle != undefined) {
- return object.$handle;
- if (hasOwnProperty(object, '$h')) {
- if (object.$h != undefined) {
- return object.$h;
- return null;
- //查看域值
- function inspectObject(obj, input) {
- var isInstance = false;
- var obj_class = null;
- if (getHandle(obj) === null) {
- obj_class = obj.class;
- } else {
- var Class = Java.use("java.lang.Class");
- obj_class = Java.cast(obj.getClass(), Class);
- isInstance = true;
- input = input.concat("Inspecting Fields: => ", isInstance, " => ", obj_class.toString());
- input = input.concat("\r\n")
- var fields = obj_class.getDeclaredFields();
- for (var i in fields) {
- if (isInstance || Boolean(fields[i].toString().indexOf("static ") >= 0)) {
- // output = output.concat("\t\t static static static " + fields[i].toString());
- var className = obj_class.toString().trim().split(" ")[1];
- // console.Red("className is => ",className);
- var fieldName = fields[i].toString().split(className.concat(".")).pop();
- var fieldType = fields[i].toString().split(" ").slice(-2)[0];
- var fieldValue = undefined;
- if (!(obj[fieldName] === undefined))
- fieldValue = obj[fieldName].value;
- input = input.concat(fieldType + " \t" + fieldName + " => ", fieldValue + " => ", JSON.stringify(fieldValue));
- return input;
- // trace单个类的所有静态和实例方法包括构造方法 trace a specific Java Method
- function traceMethod(targetClassMethod) {
- var delim = targetClassMethod.lastIndexOf(".");
- if (delim === -1) return;
- var targetClass = targetClassMethod.slice(0, delim)
- var targetMethod = targetClassMethod.slice(delim + 1, targetClassMethod.length)
- var hook = Java.use(targetClass);
- if (!hook[targetMethod]) {
- return;
- var overloadCount = hook[targetMethod].overloads.length;
- console.Red("Tracing Method : " + targetClassMethod + " [" + overloadCount + " overload(s)]");
- for (var i = 0; i < overloadCount; i++) {
- hook[targetMethod].overloads[i].implementation = function () {
- //初始化输出
- var output = "";
- //画个横线
- for (var p = 0; p < 100; p++) {
- output = output.concat("==");
- //域值
- if (!isLite) { output = inspectObject(this, output); }
- //进入函数
- output = output.concat("\n*** entered " + targetClassMethod);
- output = output.concat("\r\n")
- // if (arguments.length) console.Black();
- //参数
- var retval = this[targetMethod].apply(this, arguments);
- if (!isLite) {
- for (var j = 0; j < arguments.length; j++) {
- output = output.concat("arg[" + j + "]: " + arguments[j] + " => " + JSON.stringify(arguments[j]));
- //调用栈
- output = output.concat(Java.use("android.util.Log").getStackTraceString(Java.use("java.lang.Throwable").$new()));
- //返回值
- output = output.concat("\nretval: " + retval + " => " + JSON.stringify(retval));
- // inspectObject(this)
- //离开函数
- output = output.concat("\n*** exiting " + targetClassMethod);
- //最终输出
- // console.Black(output);
- var r = parseInt((Math.random() * 7).toFixed(0));
- var i = r;
- var printOutput = null;
- switch (i) {
- case 1:
- printOutput = console.Red;
- break;
- case 2:
- printOutput = console.Yellow;
- break;
- case 3:
- printOutput = console.Green;
- break;
- case 4:
- printOutput = console.Cyan;
- break;
- case 5:
- printOutput = console.Blue;
- break;
- case 6:
- printOutput = console.Gray;
- break;
- default:
- printOutput = console.Purple;
- printOutput(output);
- return retval;
- function traceClass(targetClass) {
- if (Java.available) {
- Java.perform(function () {
- JavaTraceClass(targetClass)
- } else if (ObjC.available) {
- IosTraceClass(targetClass)
- } else {
- console.log("please connect to either iOS or Android device ...")
- function JavaTraceClass(targetClass) {
- //Java.use是新建一个对象哈,大家还记得么?
- //利用反射的方式,拿到当前类的所有方法
- var methods = hook.class.getDeclaredMethods();
- //建完对象之后记得将对象释放掉哈
- hook.$dispose;
- //将方法名保存到数组中
- var parsedMethods = [];
- var output = "";
- output = output.concat("\tSpec: => \r\n")
- methods.forEach(function (method) {
- output = output.concat(method.toString())
- parsedMethods.push(method.toString().replace(targetClass + ".", "TOKEN").match(/\sTOKEN(.*)\(/)[1]);
- //去掉一些重复的值
- var Targets = uniqBy(parsedMethods, JSON.stringify);
- // targets = [];
- var constructors = hook.class.getDeclaredConstructors();
- if (constructors.length > 0) {
- constructors.forEach(function (constructor) {
- output = output.concat("Tracing ", constructor.toString())
- Targets = Targets.concat("$init")
- //对数组中所有的方法进行hook,
- Targets.forEach(function (targetMethod) {
- traceMethod(targetClass + "." + targetMethod);
- //画个横线
- output = output.concat("+");
- console.Green(output);
- function print_arguments(args) {
- Frida's Interceptor has no information about the number of arguments, because there is no such
- information available at the ABI level (and we don't rely on debug symbols).
- I have implemented this function in order to try to determine how many arguments a method is using.
- It stops when:
- - The object is not nil
- - The argument is not the same as the one before
- var n = 100;
- var last_arg = '';
- for (var i = 2; i < n; ++i) {
- var arg = (new ObjC.Object(args[i])).toString();
- if (arg == 'nil' || arg == last_arg) {
- break;
- last_arg = arg;
- return ' args' + (i-2) + ': ' + (new ObjC.Object(args[i])).toString()
- function IosTraceClass(targetClass) {
- console.log("Entering ios hooking => " + targetClass)
- if (ObjC.classes.hasOwnProperty(targetClass)) {
- //console.log("[+] Class: " + className);
- //var methods = ObjC.classes[className].$methods;
- var methods = ObjC.classes[targetClass].$ownMethods;
- console.log("hooking " + method);
- try {
- Interceptor.attach(ObjC.classes[targetClass][method].implementation, {
- onEnter: function (args) {
- this.output = ""
- this.output = this.output.concat("[*] Detected call to: " + targetClass + " -> " + method)
- this.output = this.output.concat("\r\n")
- this.output = this.output.concat(print_arguments(args))
- this.output = this.output.concat(Thread.backtrace(this.context, Backtracer.ACCURATE).map(DebugSymbol.fromAddress).join("\n\t"))
- // this.output = this.output.concat("\r\n")
- // console.log(JSON.stringify(args))
- // console.log(JSON.stringify(this.context, null, 4))
- // console.log(ObjC.classes.NSThread.callStackSymbols().toString())
- }, onLeave: function (ret) {
- // console.log("ret value is => ",ret ,ObjC.object(ret).toString(), "=> ",JSON.stringify(ObjC.object(ret)))
- this.output = this.output.concat("\r\nios return value => ", ret, ObjC.Object(ret).toString(), "\r\n")
- console.log(this.output)
- } catch (error) {
- console.log("ios hooking failed error is => ", error)
- function hook(white, black, target = null) {
- javahook(white, black, target)
- ioshook(white, black)
- } else {
- function javahook(white, black, target = null) {
- console.Red("start")
- if (!(target === null)) {
- console.LightGreen("Begin enumerateClassLoaders ...")
- Java.enumerateClassLoaders({
- onMatch: function (loader) {
- try {
- if (loader.findClass(target)) {
- console.Red("Successfully found loader")
- console.Blue(loader);
- Java.classFactory.loader = loader;
- console.Red("Switch Classloader Successfully ! ")
- catch (error) {
- console.Red(" continuing :" + error)
- onComplete: function () {
- console.Red("EnumerateClassloader END")
- console.Red("Begin Search Class...")
- var targetClasses = new Array();
- Java.enumerateLoadedClasses({
- onMatch: function (className) {
- if (className.toString().toLowerCase().indexOf(white.toLowerCase()) >= 0 &&
- (black == null || black == '' || className.toString().toLowerCase().indexOf(black.toLowerCase()) < 0)) {
- console.Black("Found Class => " + className)
- targetClasses.push(className);
- traceClass(className);
- }, onComplete: function () {
- console.Black("Search Class Completed!")
- var output = "On Total Tracing :" + String(targetClasses.length) + " classes :\r\n";
- targetClasses.forEach(function (target) {
- output = output.concat(target);
- console.Green(output + "Start Tracing ...")
- function ioshook(white, black) {
- console.log("iOS begin search classed ...")
- const resolver = new ApiResolver('objc');
- var rule = '*[*' + white + '* *:*]'
- // var rule = '*[*' + white + '* *:*]';
- console.log("Search rule is => ", rule)
- const matches = resolver.enumerateMatches(rule);
- var targetClasses = new Set()
- matches.forEach((match) => {
- if (match.name.toString().toLowerCase().indexOf(String(black).toLowerCase()) < 0) {
- console.log(JSON.stringify(match) + "=>" + match["name"].toString().split('[')[1].toString().split(' ')[0])
- targetClasses.add(match["name"].toString().split('[')[1].toString().split(' ')[0])
- // Interceptor.attach(match.address,{
- // onEnter: function(args) {
- // this.output = ""
- // this.output = this.output.concat( "[*] Detected call to: " + match.name)
- // this.output = this.output.concat(print_arguments(args))
- // this.output = this.output.concat(Thread.backtrace(this.context, Backtracer.ACCURATE).map(DebugSymbol.fromAddress).join("\n\t"))
- // // console.log(JSON.stringify(args))
- // // console.log(JSON.stringify(this.context, null, 4))
- // // console.log(ObjC.classes.NSThread.callStackSymbols().toString())
- // } , onLeave:function(ret){
- // // console.log("ret value is => ",ret ,ObjC.object(ret).toString(), "=> ",JSON.stringify(ObjC.object(ret)))
- // this.output = this.output.concat("\r\nios return value => ",ret, ObjC.Object(ret).toString(),"\r\n")
- // console.log(this.output)
- targetClasses.forEach((className) => {
- console.log("ios final hooking => ", className)
- function hookALL() {
- JavahookALL()
- ioshookALL()
- } else {
- function ioshookALL() {
- console.log("[*] iOS Started: Hook all methods of all app only classes");
- var free = new NativeFunction(Module.findExportByName(null, 'free'), 'void', ['pointer'])
- var copyClassNamesForImage = new NativeFunction(Module.findExportByName(null, 'objc_copyClassNamesForImage'), 'pointer', ['pointer', 'pointer'])
- var p = Memory.alloc(Process.pointerSize)
- Memory.writeUInt(p, 0)
- var path = ObjC.classes.NSBundle.mainBundle().executablePath().UTF8String()
- var pPath = Memory.allocUtf8String(path)
- var pClasses = copyClassNamesForImage(pPath, p)
- var count = Memory.readUInt(p)
- var classesArray = new Array(count)
- for (var i = 0; i < count; i++) {
- var pClassName = Memory.readPointer(pClasses.add(i * Process.pointerSize))
- classesArray[i] = Memory.readUtf8String(pClassName)
- var className = classesArray[i]
- free(pClasses)
- console.log("[*] iOS Completed: Hook all methods of all app only classes");
- function hookALLappClasses(loader) {
- if (loader.$className.toString().indexOf("java.lang.BootClassLoader") >= 0) {
- return
- var class_BaseDexClassLoader = Java.use("dalvik.system.BaseDexClassLoader");
- var pathcl = Java.cast(loader, class_BaseDexClassLoader);
- console.log("classloader pathList", pathcl.pathList.value);
- var class_DexPathList = Java.use("dalvik.system.DexPathList");
- var dexPathList = Java.cast(pathcl.pathList.value, class_DexPathList);
- console.log("classloader dexElements:", dexPathList.dexElements.value.length);
- var class_DexFile = Java.use("dalvik.system.DexFile");
- var class_DexPathList_Element = Java.use("dalvik.system.DexPathList$Element");
- for (var i = 0; i < dexPathList.dexElements.value.length; i++) {
- var dexPathList_Element = Java.cast(dexPathList.dexElements.value[i], class_DexPathList_Element);
- // console.log("classloader .dexFile:",dexPathList_Element.dexFile.value);
- //可能为空 为空跳过
- if (dexPathList_Element.dexFile.value) {
- var dexFile = Java.cast(dexPathList_Element.dexFile.value, class_DexFile);
- var mcookie = dexFile.mCookie.value;
- // console.log(".mCookie",dexFile.mCookie.value);
- if (dexFile.mInternalCookie.value) {
- mcookie = dexFile.mInternalCookie.value;
- var classNameArr =
- dexPathList_Element.dexFile.value.getClassNameList(mcookie);
- console.log("dexFile.getClassNameList.length:", classNameArr.length);
- console.log("r0ysue-Enumerate ClassName Start");
- for (var i = 0; i < classNameArr.length; i++) {
- if (classNameArr[i].indexOf("android.") < 0 &&
- classNameArr[i].indexOf("androidx.") < 0 &&
- classNameArr[i].indexOf("java.") < 0 &&
- classNameArr[i].indexOf("javax.") < 0
- console.log("r0ysue ", classNameArr[i]);
- traceClass(classNameArr[i])
- console.log("r0ysue-Enumerate ClassName End");
- function JavahookALL() {
- console.log("Entering Android hookALL procedure ...")
- try {
- if (loader.toString().indexOf("base.apk") >= 0 &&
- loader.toString().indexOf(".jar") < 0) {
- console.Red("Successfully found app specifec classloader")
- hookALLappClasses(loader)
- catch (error) {
- function main() {
- console.Purple("r0tracer begin ... !")
- //0. 增加精简模式,就是以彩虹色只显示进出函数。默认是关闭的,注释此行打开精简模式。
- //isLite = true;
- //以下三种模式,取消注释某一行以开启
- //A. 简易trace单个lei
- // traceClass("ViewController")
- //B. 黑白名单trace多个函数,第一个参数是白名单(包含关键字),第二个参数是黑名单(不包含的关键字)
- // hook("com.uzmap.pkg.EntranceActivity", "$");
- //C. 报某个类找不到时,将某个类名填写到第三个参数,比如找不到com.roysue.check类。(前两个参数依旧是黑白名单)
- // hook("com.roysue.check"," ","com.roysue.check");
- //D. 新增hookALL() 打开这个模式的情况下,会hook属于app自己的所有业务类,小型app可用 ,中大型app几乎会崩溃,经不起
- // hookALL()
- //setImmediate是立即执行函数,setTimeout是等待毫秒后延迟执行函数
- //二者在attach模式下没有区别
- //在spawn模式下,hook系统API时如javax.crypto.Cipher建议使用setImmediate立即执行,不需要延时
- //在spawn模式下,hook应用自己的函数或含壳时,建议使用setTimeout并给出适当的延时(500~5000)
- setImmediate(main)
- // setTimeout(main, 2000);
- // 玄之又玄,众妙之门
- // Frida的崩溃有时候真的是玄学,大项目一崩溃根本不知道是哪里出的问题,这也是小而专的项目也有一丝机会的原因
- // Frida自身即会经常崩溃,建议多更换Frida(客/服要配套)版本/安卓版本,我自己常用的组合是两部手机,Frida12.8.0全家桶+安卓8.1.0,和Frida14.2.2全家桶+安卓10
