作者你好
查看38 | 回复1 | 昨天 00:58 来自手机 | 显示全部楼层 |阅读模式
作者你好,MemScanner 的 KPM 在我这台机器加载失败,麻烦看下能否适配。
' E4 Q' ^! B- O4 {  D5 @; Y' K" h4 s7 V( c" D
设备:OnePlus NE2213(一加 10 Pro),Android 16 / API 36& b$ N9 l  S8 c. C
内核:5.10.236-android12-9-o-g9cbeeefc70f0 #1 SMP PREEMPT3 H9 v# B! f" K# K- g
环境:APatch 0.13.9 (11282) Full,KernelPatch 0.13.9 d09,SELinux Permissive5 T, a+ Z1 ~$ g# X) j0 e& `
KPM 包:nixiang.kpm(name @nixiang,version 1.0,author 逆想 nixiang.tech),装在 /data/adb/ap/kpm/nixiang/4 E' t/ z* @+ V6 X9 q  a
现象:APatch 里显示已安装、开关打开,但开机加载 rc=-1,loaded=0,客户端一直退回「Root兼容」后端。6 [, i" w- G; h/ o! t) t5 s
# M. r4 b% P2 }7 F( P% Vdmesg 关键行:3 V7 {# ^! t8 \6 T) U. ~
[+] KP D load_module_path_event: /data/adb/ap/kpm/nixiang/nixiang.kpm  s; t* a+ R# D- e4 g! S
[+] KP D     name: @nixiang   version: 1.0   license: GPL v2: ^* H% e, ?% I1 W! ]
[@nixiang]compat: user_nofault=copy_from_user_nofault8 s' [/ M; F( @2 Q4 W
[@nixiang]compat: task_put=unavailable usage_offset=-1 (process context only)
7 m/ ?) m6 l* y" C[@nixiang]compat: task_get=unavailable7 K# I0 C, S& p
[@nixiang]compat: prepared_cred_release=abort_creds (owned prepared cred only)! H9 j- f0 W( t% G
[@nixiang]compat: boot_clock=ktime_get_boottime_ns
# c! y6 [% w, L- b[@nixiang]compat: linear_ram=memblock_is_map_memory) M& V" f, Y- w6 A4 ~9 v
[@nixiang]compat: missing required owned task lookup/release- m+ m) a) F( Q) ^( {
[@nixiang]compat: watch=1 wide=1 (optional)
9 D; i4 @$ e# \; y& N[@nixiang]init: required kernel symbols missing, abort load. `) |# f, K& @
[+] KP I load_module_ex: [@nixiang] failed with [(null)] error: -1, try exit ..., ], Y6 Z/ @9 m  I  R: q: d
KP load AP KPM: ... rc: -1
0 _* X2 {5 `- z8 [3 AKP AP KPM loading done: loaded=0 skipped=0 total=1
7 E) d& m7 y. ~1 |. V1 n/ x3 }% a1 [
看起来是 KPM 依赖的 task_get / task_put 在这个 OPPO/一加 5.10 内核上不可用导致 init 直接 abort。
8 R7 S2 I9 @# m; B+ \& ~, P想问:是否有适配该内核(或走兼容层/替代实现)的 KPM 版本?如果有,麻烦说明放哪个路径、要不要额外参数。
logic | 昨天 03:50 来自手机 | 显示全部楼层
收到反馈
