很多小伙伴们在抓包时总会出现网络异常抓不到包,这是因为被抓包应用有抓包检测,所以要想成功打开软件抓到包,自然就必须解决掉相应检测函数。本js脚本hook范围包括:
1.SSLcontext
2.okhttp
3.webview
4.XUtils
5.httpclientandroidlib
6.JSSE
7.network\_security\_config (android 7.0+)
8.Apache Http client (support partly)
9.OpenSSLSocketImpl
10.TrustKit
11.Cronet
当然,这仅仅是最基本的java层检测手段,so层还需要对软件反编译找到加载调用的相关so文件,利用强大的ida去进一步分析等等
- Java.perform(function() {
- // Attempts to bypass SSL pinning implementations in a number of
- // ways. These include implementing a new TrustManager that will
- // accept any SSL certificate, overriding OkHTTP v3 check()
- // method etc.
- var X509TrustManager = Java.use('javax.net.ssl.X509TrustManager');
- var HostnameVerifier = Java.use('javax.net.ssl.HostnameVerifier');
- var SSLContext = Java.use('javax.net.ssl.SSLContext');
- var quiet_output = false;
- // Helper method to honor the quiet flag.
- function quiet_send(data) {
- if (quiet_output) {
- return;
- send(data)
- // Implement a new TrustManager
- // ref: https://gist.github.com/oleavr/3ca67a173ff7d207c6b8c3b0ca65a9d8
- // Java.registerClass() is only supported on ART for now(201803). 所以android 4.4以下不兼容,4.4要切换成ART使用.
- 06-07 16:15:38.541 27021-27073/mi.sslpinningdemo W/System.err: java.lang.IllegalArgumentException: Required method checkServerTrusted(X509Certificate[], String, String, String) missing
- 06-07 16:15:38.542 27021-27073/mi.sslpinningdemo W/System.err: at android.net.http.X509TrustManagerExtensions.<init>(X509TrustManagerExtensions.java:73)
- at mi.ssl.MiPinningTrustManger.<init>(MiPinningTrustManger.java:61)
- 06-07 16:15:38.543 27021-27073/mi.sslpinningdemo W/System.err: at mi.sslpinningdemo.OkHttpUtil.getSecPinningClient(OkHttpUtil.java:112)
- at mi.sslpinningdemo.OkHttpUtil.get(OkHttpUtil.java:62)
- at mi.sslpinningdemo.MainActivity$1$1.run(MainActivity.java:36)
- var X509Certificate = Java.use("java.security.cert.X509Certificate");
- var TrustManager;
- try {
- TrustManager = Java.registerClass({
- name: 'org.wooyun.TrustManager',
- implements: [X509TrustManager],
- methods: {
- checkClientTrusted: function(chain, authType) {},
- checkServerTrusted: function(chain, authType) {},
- getAcceptedIssuers: function() {
- // var certs = [X509Certificate.$new()];
- // return certs;
- return [];
- } catch (e) {
- quiet_send("registerClass from X509TrustManager >>>>>>>> " + e.message);
- // Prepare the TrustManagers array to pass to SSLContext.init()
- var TrustManagers = [TrustManager.$new()];
- try {
- // Prepare a Empty SSLFactory
- var TLS_SSLContext = SSLContext.getInstance("TLS");
- TLS_SSLContext.init(null, TrustManagers, null);
- var EmptySSLFactory = TLS_SSLContext.getSocketFactory();
- } catch (e) {
- quiet_send(e.message);
- send('Custom, Empty TrustManager ready');
- // Get a handle on the init() on the SSLContext class
- var SSLContext_init = SSLContext.init.overload(
- '[Ljavax.net.ssl.KeyManager;', '[Ljavax.net.ssl.TrustManager;', 'java.security.SecureRandom');
- // Override the init method, specifying our new TrustManager
- SSLContext_init.implementation = function(keyManager, trustManager, secureRandom) {
- quiet_send('Overriding SSLContext.init() with the custom TrustManager');
- SSLContext_init.call(this, null, TrustManagers, null);
- /*** okhttp3.x unpinning ***/
- // Wrap the logic in a try/catch as not all applications will have
- // okhttp as part of the app.
- try {
- var CertificatePinner = Java.use('okhttp3.CertificatePinner');
- quiet_send('OkHTTP 3.x Found');
- CertificatePinner.check.overload('java.lang.String', 'java.util.List').implementation = function() {
- quiet_send('OkHTTP 3.x check() called. Not throwing an exception.');
- var OkHttpClient$Builder = Java.use('okhttp3.OkHttpClient$Builder');
- quiet_send('OkHttpClient$Builder Found');
- console.log("hostnameVerifier", OkHttpClient$Builder.hostnameVerifier);
- OkHttpClient$Builder.hostnameVerifier.implementation = function () {
- quiet_send('OkHttpClient$Builder hostnameVerifier() called. Not throwing an exception.');
- return this;
- var myHostnameVerifier = Java.registerClass({
- name: 'com.xiaojianbang.MyHostnameVerifier',
- implements: [HostnameVerifier],
- methods: {
- verify: function (hostname, session) {
- return true;
- var OkHttpClient = Java.use('okhttp3.OkHttpClient');
- OkHttpClient.hostnameVerifier.implementation = function () {
- quiet_send('OkHttpClient hostnameVerifier() called. Not throwing an exception.');
- return myHostnameVerifier.$new();
- } catch (err) {
- // If we dont have a ClassNotFoundException exception, raise the
- // problem encountered.
- if (err.message.indexOf('ClassNotFoundException') === 0) {
- throw new Error(err);
- // Appcelerator Titanium PinningTrustManager
- // appcelerator as part of the app.
- try {
- var PinningTrustManager = Java.use('appcelerator.https.PinningTrustManager');
- send('Appcelerator Titanium Found');
- PinningTrustManager.checkServerTrusted.implementation = function() {
- quiet_send('Appcelerator checkServerTrusted() called. Not throwing an exception.');
- } catch (err) {
- /*** okhttp unpinning ***/
- try {
- var OkHttpClient = Java.use("com.squareup.okhttp.OkHttpClient");
- OkHttpClient.setCertificatePinner.implementation = function(certificatePinner) {
- // do nothing
- quiet_send("OkHttpClient.setCertificatePinner Called!");
- return this;
- // Invalidate the certificate pinnet checks (if "setCertificatePinner" was called before the previous invalidation)
- var CertificatePinner = Java.use("com.squareup.okhttp.CertificatePinner");
- CertificatePinner.check.overload('java.lang.String', '[Ljava.security.cert.Certificate;').implementation = function(p0, p1) {
- // do nothing
- quiet_send("okhttp Called! [Certificate]");
- return;
- CertificatePinner.check.overload('java.lang.String', 'java.util.List').implementation = function(p0, p1) {
- // do nothing
- quiet_send("okhttp Called! [List]");
- return;
- } catch (e) {
- quiet_send("com.squareup.okhttp not found");
- /*** WebView Hooks ***/
- /* frameworks/base/core/java/android/webkit/WebViewClient.java */
- /* public void onReceivedSslError(Webview, SslErrorHandler, SslError) */
- var WebViewClient = Java.use("android.webkit.WebViewClient");
- WebViewClient.onReceivedSslError.implementation = function(webView, sslErrorHandler, sslError) {
- quiet_send("WebViewClient onReceivedSslError invoke");
- //执行proceed方法
- sslErrorHandler.proceed();
- return;
- WebViewClient.onReceivedError.overload('android.webkit.WebView', 'int', 'java.lang.String', 'java.lang.String').implementation = function(a, b, c, d) {
- quiet_send("WebViewClient onReceivedError invoked");
- return;
- WebViewClient.onReceivedError.overload('android.webkit.WebView', 'android.webkit.WebResourceRequest', 'android.webkit.WebResourceError').implementation = function() {
- return;
- /*** JSSE Hooks ***/
- /* libcore/luni/src/main/java/javax/net/ssl/TrustManagerFactory.java */
- /* public final TrustManager[] getTrustManager() */
- /* TrustManagerFactory.getTrustManagers maybe cause X509TrustManagerExtensions error */
- // var TrustManagerFactory = Java.use("javax.net.ssl.TrustManagerFactory");
- // TrustManagerFactory.getTrustManagers.implementation = function(){
- // quiet_send("TrustManagerFactory getTrustManagers invoked");
- // return TrustManagers;
- var HttpsURLConnection = Java.use("com.android.okhttp.internal.huc.HttpsURLConnectionImpl");
- HttpsURLConnection.setSSLSocketFactory.implementation = function(SSLSocketFactory) {
- quiet_send("HttpsURLConnection.setSSLSocketFactory invoked");
- HttpsURLConnection.setHostnameVerifier.implementation = function(hostnameVerifier) {
- quiet_send("HttpsURLConnection.setHostnameVerifier invoked");
- /*** Xutils3.x hooks ***/
- //Implement a new HostnameVerifier
- var TrustHostnameVerifier;
- try {
- TrustHostnameVerifier = Java.registerClass({
- name: 'org.wooyun.TrustHostnameVerifier',
- method: {
- verify: function(hostname, session) {
- return true;
- } catch (e) {
- //java.lang.ClassNotFoundException: Didn't find class "org.wooyun.TrustHostnameVerifier"
- quiet_send("registerClass from hostnameVerifier >>>>>>>> " + e.message);
- try {
- var RequestParams = Java.use('org.xutils.http.RequestParams');
- RequestParams.setSslSocketFactory.implementation = function(sslSocketFactory) {
- sslSocketFactory = EmptySSLFactory;
- return null;
- RequestParams.setHostnameVerifier.implementation = function(hostnameVerifier) {
- hostnameVerifier = TrustHostnameVerifier.$new();
- return null;
- } catch (e) {
- quiet_send("Xutils hooks not Found");
- /*** httpclientandroidlib Hooks ***/
- try {
- var AbstractVerifier = Java.use("ch.boye.httpclientandroidlib.conn.ssl.AbstractVerifier");
- AbstractVerifier.verify.overload('java.lang.String', '[Ljava.lang.String', '[Ljava.lang.String', 'boolean').implementation = function() {
- quiet_send("httpclientandroidlib Hooks");
- return null;
- } catch (e) {
- quiet_send("httpclientandroidlib Hooks not found");
- android 7.0+ network_security_config TrustManagerImpl hook
- apache httpclient partly
- var TrustManagerImpl = Java.use("com.android.org.conscrypt.TrustManagerImpl");
- // try {
- // var Arrays = Java.use("java.util.Arrays");
- // //apache http client pinning maybe baypass
- // //https://github.com/google/conscrypt/blob/c88f9f55a523f128f0e4dace76a34724bfa1e88c/platform/src/main/java/org/conscrypt/TrustManagerImpl.java#471
- // TrustManagerImpl.checkTrusted.implementation = function (chain, authType, session, parameters, authType) {
- // quiet_send("TrustManagerImpl checkTrusted called");
- // //Generics currently result in java.lang.Object
- // return Arrays.asList(chain);
- // } catch (e) {
- // quiet_send("TrustManagerImpl checkTrusted nout found");
- try {
- // Android 7+ TrustManagerImpl
- TrustManagerImpl.verifyChain.implementation = function(untrustedChain, trustAnchorChain, host, clientAuth, ocspData, tlsSctData) {
- quiet_send("TrustManagerImpl verifyChain called");
- // Skip all the logic and just return the chain again :P
- //https://www.nccgroup.trust/uk/about-us/newsroom-and-events/blogs/2017/november/bypassing-androids-network-security-configuration/
- // https://github.com/google/conscrypt/blob/c88f9f55a523f128f0e4dace76a34724bfa1e88c/platform/src/main/java/org/conscrypt/TrustManagerImpl.java#L650
- return untrustedChain;
- } catch (e) {
- quiet_send("TrustManagerImpl verifyChain nout found below 7.0");
- // OpenSSLSocketImpl
- try {
- var OpenSSLSocketImpl = Java.use('com.android.org.conscrypt.OpenSSLSocketImpl');
- OpenSSLSocketImpl.verifyCertificateChain.implementation = function(certRefs, authMethod) {
- quiet_send('OpenSSLSocketImpl.verifyCertificateChain');
- quiet_send('OpenSSLSocketImpl pinning')
- } catch (err) {
- quiet_send('OpenSSLSocketImpl pinner not found');
- // Trustkit
- try {
- var Activity = Java.use("com.datatheorem.android.trustkit.pinning.OkHostnameVerifier");
- Activity.verify.overload('java.lang.String', 'javax.net.ssl.SSLSession').implementation = function(str) {
- quiet_send('Trustkit.verify1: ' + str);
- return true;
- Activity.verify.overload('java.lang.String', 'java.security.cert.X509Certificate').implementation = function(str) {
- quiet_send('Trustkit.verify2: ' + str);
- return true;
- quiet_send('Trustkit pinning')
- } catch (err) {
- quiet_send('Trustkit pinner not found')
- try {
- //cronet pinner hook
- //weibo don't invoke
- var netBuilder = Java.use("org.chromium.net.CronetEngine$Builder");
- //https://developer.android.com/guide/topics/connectivity/cronet/reference/org/chromium/net/CronetEngine.Builder.html#enablePublicKeyPinningBypassForLocalTrustAnchors(boolean)
- netBuilder.enablePublicKeyPinningBypassForLocalTrustAnchors.implementation = function(arg) {
- //weibo not invoke
- console.log("Enables or disables public key pinning bypass for local trust anchors = " + arg);
- //true to enable the bypass, false to disable.
- var ret = netBuilder.enablePublicKeyPinningBypassForLocalTrustAnchors.call(this, true);
- return ret;
- netBuilder.addPublicKeyPins.implementation = function(hostName, pinsSha256, includeSubdomains, expirationDate) {
- console.log("cronet addPublicKeyPins hostName = " + hostName);
- //var ret = netBuilder.addPublicKeyPins.call(this,hostName, pinsSha256,includeSubdomains, expirationDate);
- //this 是调用 addPublicKeyPins 前的对象吗? Yes,CronetEngine.Builder
- return this;
- } catch (err) {
- console.log('[-] Cronet pinner not found')
